1 - 7 of 7 Posts
Hello friends. I´m currently building a D16Z6 with a Crower 3 Cam, Running pure Ethanol as fuel. Injectors are BOSCH 0280.155.968 green giant 441cc 12 - 14.5 Ohms. Pistons are P29 with 13:1 comp. Race port. Need help with a Crome Gold Basemap to get this thing running. I will be tuning fuel ASAP, but wont get to a dyno for a few weeks to tune timing. Thank you so much if you can help. Will post dyno sheet when I get it.
What platform? S300 comes with a P28 basemap that will get you 90% of the way there.
I run Crower 3 and 12.5:1 on the stock P28 basemap with 33% fuel added because I run E85
I didn't touch timing except remove a few degrees in high load 5th gear. Runs great and pulls hard.
Discussion Starter · #4 ·
Thanks for the reply. I´m going to tune on crome pro gold. The Fuel I´m not too concerned. I was concerned about timing. where in the Manifold preassure reading did you pull timing and how much? thanks
1 - 7 of 7 Posts
