1 - 20 of 24 Posts
so any recommended website or any help
i got a skunk2 cam gear just need to know
how to adjust the setting or the cam
the cam is goin on a mini me swap
d17 block and y8 head
any help would be great!!!!
Put it on a dyno and move it 2 degrees at a time and see what happens. Once you find a range move it a half degree at a time to fine tune it.
but then the whole point of puttin in the cam is for its performance....
if set at zero then whats the point?
A cam gear is only going to move where your powerband is, that's about it. Besides, I'm 99.99999999999% sure the Y8 head won't bolt onto a D17 block.
looks like u need to do some research prior to buying parts, cus it sounds like u have no idea how things are done the correct way
but if u want to have some fun advance the timing about 6 degrees, it will make the VtAc hit twice as hard!!!!
and we all know that when it comes to VtAc, the louder the better
yeah thats why im in this thread asking for help duhhhh
google can help u more then u think...;)
edit: if u search this page , u can find lots of threads on tunning
im sure ull be able to find something that will give a better idea of what tunning is all about
and they did help u.. accept the help.. dont expect what u wana hear if its not the correct aproach...
street tuning = fixing ur a/f and putting the timing maps in a way that is safe and wont make ur motor self deteriorate,
tuning to make more power = via dyno... only..
camgear, useful to fix any corrections (sometimes) but to gain anything even just 1whp? will be on the dyno..
that was a good advice earlier.. set it to zero and street tune ur car.. atleast u know it wont die when u drive it hard..
okay so is the z6 throttle body bigger or the y8...i heard with the z6 throttle body its like the perfect combination for a mini me swap?
so????
yeah its possible...its done on my car its a mini me swap....
sorry wrong posting
its a d16y7 block not a d17 block
damm u cant even read what ur typing before u post....:sadface:
what u need to do is start using the "search" bottom at the top of the page and STOP using the "post" feature of this web site
there is alot of threads about mini-me swaps on this forum.
"this is D-series.org not spoon-feed-the-noob.org"
99ej6t
Discussion Starter #18
99ej6t
uhhh sure if you dont like it then get off iaint making you come in and out of my thread idiot
1 - 20 of 24 Posts
