1 - 15 of 15 Posts
Civic Si (Canada)
I just bought a ractive electronic oil pressure gauge and need to know if there any way to install the pressure sender without having a fitting on the oil filter?
D-series wise guy
I know that...but plenty of people have doen it with a short adapter and tee without a problem. I think most of the people having problems used too long of a tee
Lets not teach people what we know is the wrong way to do something. I've seen a lot of "normal" things on hondas that make me shake my head...
I bought one of the ports from tuner toys, some copper tube and a conduit clamp to remote mount my sending unit on the firewall. I haven't installed it yet, but I'll post up pics when I do.
Civic Si (Canada)
I am getting 30psi at idle and 80psi from 3k to wot. I use 10W30 castrol with 1/2 liter of Lucas oil additive every time I change my oil. Is that seam ok or should think about shim the oil pump???
coper line doesn't belong on a car.
92 Honda Civic VTI
seems fine thats pretty much what i get in mine
35psi at idle and 70PSI ove 3500rpm
honda says it needs to be more than 50psi at 3000rpm
Civic Si (Canada)
You don't trust Lucas or what? It's been using in race car since a while. I know it's reduce oil consumption and smoke in my old civic.
1 - 15 of 15 Posts
