1 - 11 of 11 Posts
hey folks, first time on a honda forum.
i am a mechanic for Ford commercial and Mack Trucks. I do all my own work on my vehicles, i have an 05 civic dx with a 1.7 w/ 5 speed manual. when i bought it a few years back it had some bearing noise, i assumed it was a throw out bearing since it would go away with the clutch pushed in. so i put a clutch in it a few months ago when it started slipping, only to discover my noise was still there. did a little online research and found it is a common issue for manual honda transmissions to have input/main shaft bearing failure. so i am about to start pulling the engine and trans tonight. going to catch some oil seals on the engine while i am in there, and fix the trans.
i have a good mechanical knowledge, though i am 99% a diesel mechanic, and a heavy duty mechanic at that. first time in a transaxle.
i am looking at parts diagrams online and am having a hard time seeing what i think i will need to order. i am not going to order anything until i have disassembled the unit and seen what all is failing. no transmission shops local to me touch manual imports so no help from them for parts ordering.
I am hoping once i have the unit apart, you guys can help me order the correct parts the first time, to minimize down time. I'll be riding my motorcycle to work during these repairs.
i see one bearing on the main shaft, but i cannot find the oil seals on the diagrams. i will upload the diagrams i am looking at. along with screen shots of the part numbers.
Also, I haven't been into the 01-05 trans.
Where are you located?
nice, thanks. i am in central georgia, macon/milledgeville area. i should have the drivetrain out thursday, working full time, i don't like to spend a lot of time at home working more, so taking it in small steps. got the oil drained from engine and trans, axles out, air inlet system off. going to pull accessories and such tonight. i don't know for sure what i will replace, i want it fixed 100% the first time. so if other things show abnormal wear i'll fix that as well, but hoping its just input shaft bearings. will do axle shaft seals while i'm there. was wanting to swap some gears to a shorter ratio, but life hit me hard this weekend and had to drain almost all my savings account. some scum bag arrested my wife because she didn't have her medication in the original bottle, she had them in a weekly pill minder box. what a douche, treated us like some crackheads.. but that is another story in itself.
i always like to replace with OEM parts, but in this case, with the oem bearings being such an issue, i would rather replace with a higher quality, unless oem is what seems to be the best. i just don't want this to end up being an every 80,000 mile thing. lol
1996 Civic Type DX
NTN is the supplier for almost every Honda bearing. The Synchrotech kits come with NTN bearings. It's not a bearing issue, just a small design issue with the trans.
Discussion Starter · #8 ·
could you go into detail a little? maybe an oiling concern for the bearing?? anything i can do to help prevent future failures??
i have a 6 speed in my wife's '16 civic, do there seem to be any common issues with that transmission?
i have owned Honda's forever, yet know hardly nothing about them, since they rarely tear up. lol my daily 96 civic has over 500k miles, original engine, original auto trans. been a dang good car for us. its time to put it down until we have the time and money to go through it and do a solid refurbish. trans is starting to shift weird, and slipped for the first time today. cannot complain since its only gone 2-3 times the normal mileage without a major failure. the most i've done to that car is an alternator and distributor, aside form standard timing belt stuff every 100k.
1996 Civic Type DX
The bearing is held in the case by the mainshaft and has a very tight clearance to the mainshaft OD so overtime thrust loads will kill the bearing, nothing can be done to prevent it.
The L15's don't have any big issues.
Where are you located? Does the trans have any other issues?
If you just want to replace the bearing and all seals this is what you need.
91002-PS0-013
91205-PL3-A01
91216-PL3-005
91206-PHR-003
If you want to replace all of the bearings (excluding differential) and seals, order this
since money is tight, i am going to only replace the bearings on the input shaft, and the seals. i also want to replace the axle seals while i am in there. if i order one each of the highlighted part numbers, would that be enough to do the job, or is there anything i should order two of?? just dont want to waste time waiting on another parts order by getting the wrong stuff the first time. thanks for your help.
also, the clutch, pilot and throw out bearings are new, less than 15k miles. since the input shaft bearing was failing, should i go ahead and replace the pilot bearing while i am there, possible the pilot bearing has had abnormal force or alignment issues with the bearing on the other side of the shaft failing?
1996 Civic Type DX
One of each. If you don't want to wait on parts, order a pilot bearing and top mainshaft bearing.
1 - 11 of 11 Posts
