B
brotharon
·Guest
Ok, I am driving my car home when there is this tapping sound that starts up in the front of the car. I was only a little ways from home, so I drove it straight home and popped the hood to see if there was anything odd going on. COuldnt see anything, so I turned it back on to see where the noise is coming from. It is coming from something under the valve cover. I take the valve cover off, and discover that all bu two of the bolts are sheared off of the valve cover (they just pulled out without having to be loosened). I thought that may have been what was making the noise, but I was wrong, I started the car again, and again the noise. I took the valve cover off again and stared at the valvetrain for about 20 minutes, then I got out my haynes manual. I decided (because I am a super idiot) that the valves may need adjusted, so I got right to work on that. I set the engine at TDC as per the haynes manual, and proceeded to adjust the valve clearances until they met with the listed tolerances. No dice, car still runs like ass. At this point I am like screw it, so I pull the rocker arm assembly off the top and have a good look at the camshaft. Nada, nothing wrong with the camshaft, all the valve springs and retainers appear to be in good order, everything on the assembly that I removed seems to be fine as well. I put it all back together and get it all tightened down, and lo and behold now the son of a bitch won't start. I need help because this is my daily driver, and I have to go to work tomorrow. I can have my GF take me to work for a few days, but she will get real sick of waking up at the asscrack of dawn with me real quick.
Please Help Me, if you live near Everett Washington and know your ass from a hole in the ground about D16's (unlike me) I would be most greatful if you could take some time to help a brotha out.
