1 - 14 of 14 Posts
Hey guy I finally got around to install my turbo. I was running 7psi on a stock t25 so i decided to rais up the boost I got XS power boost controller and installed it right or so I think so but when I rais up the boost to 10psi It was running great for 10 minutes or so. It pulled strong but when I took it for a freeway drive it the boost went down to 4 and I could not find the problem so I blame the boost controller maybe it was broken. I took it of to see if it was the boost controller and connected everything an still 4psi WTF now I am piss of and cant find the problem.HELP GUYS:confused:
exhaust leak pre-turbo, or boost leak somewhere
Bingo,a boost controller won't turn the boost down past what it's set at,at the wastegate
so it could be a boost leak dam long day tommorow any advice on how to do it the easy way if there is one.
Soapy Water WTF wont that make things worse? dont mean to be hard headed but please explain how can I do this.
insert user title here
cap off the charge piping that goes into the tb.
makes up an air filler adapter for the opposite end ( turbo duhh )
use a bicycle pump and pump to say 20 psi.
spray soapy water on all the couplings and weld joints.
the leaks will make bubbles.
"ALRIGHTY THEN" wow got so exited that ACE VENTURA CAME ON thanks bro will do this tommorow for sure.
Alright I found the problem the inercooler piping was lose and it had a very small gap now everything works great. thanks againg guys
1 - 14 of 14 Posts
