formerly Kit88
My engine is fucked up again, and I can´t find a d16z6 block, I found a d16a6 block from a member here, just need yo know, if everything is gonna fit right on this a6 block, I´m talking about oil pump, water pump, timing belt and tensioner, crankcase, etc.
Also need to know If the compresion is gonna change using this block/head
Thanks in advance.
I got a a6 block for the crankshaft, when i was building my y8. I rember the oil pumps being diffrent. But thats for a y8
A6 and Z6 blocks have the same dimensions, dunno about the pump/tensioner stuff.
Compression wouldn't change if your keeping your rod/piston/head combo
a6 + 92-93 z6 have the same oil pump
94-95 z6 has a different oil pump <- the "upgraded upmp"
^they swap
tensioner is different, by part number. will one work for the other? i have no idea. i would not mess with this one too much. besides unless the tensioner is frozen/stuck, there is no real reason to swap it out.
water pump also has a different part number, will it swap over... yeah probably. since the 88-00 d is very very similar when it comes to the water pump.
crankshaft is the same.
side note: the tensioner and water pump where made by two different companies and could be the reason between the two different part numbers. i would be willing to bet that the parts are swapable, since the a6 and z6 blocks are cast nearly identical.
formerly Kit88
Thanks guys, hopefully everything is gonna fit without problems, my a6 block is on my way.
