1 - 4 of 4 Posts
How do i install my hondata 4 port Boost by gear solenoid says MAC on the solenoid. I have the fittings and i know where to mount those.. But the two wires where do i mount that? the two wires are black. and no instructions on where to mount the wires?? i need help and want to make sure i do it right.
i have a 1995 civic vx with my ECU is a p28 HondataS300V3 says built in boost by gear?
where do i mount these wires both black wires. do i mount the boost by gear with the extra wires sticking out of my hondata s300v3 aux. wires? or how can i insall this i wanna make sure i do it right...
need help thanks….
\/Your Mom Was Here\/
Vibe GT
I don't know much about this stuff to be honest, never tuned any Honda's I owned. But this may help
This has pictures too, and a few other things about the boost by gear.
https://www.hondata.com/help/smanager/index.html?boostcontrolecupreparation.htm
• One wire should be connected to the ECU(US) pin A11 or to the ECU(JDM) pin A17.
• One wire should be connected to +12V switched power via a 10A fuse when using a US ECU. When using a JDM ECU, one wire should be connected to a common ground.
1 - 4 of 4 Posts
