Hi! I have installed a Universal Power Window Kit in my 92 Civic Dx Hatch and it tells me to connect the power wire to a ACC source but, I dont kno where it is. I kno theres one for the car stereo but when i connect it there it blows the fuse. Can someone please help me to where else I can hook up the wire to another ACC wire source?
FAMILY MEMBER #316
i think its a 12ga black with white wire at the ignition switch
do you know how to test for the wire with a voltmeter?
No, I dont know or have a voltmeter. Usually how i test is to actually hook the wire up to it and see if it works.
FAMILY MEMBER #316
its either black with white or black with yellow or solid yellow at the ignition harness. i never bothered to memorize them because i always had a voltmeter. its NOT solid white though. do you have a test light? it should light up when the key is in the 1st position but NOT during crank and off when key isnt turned
