Del Sol
Hi all, my dad has a Del sol which is currently giving him trouble.
The engine is a D15b Vtec (JDM). It stalls randomly while driving or while on idle, then doesn't start. After a few tries it starts and CEL goes on. With the CEL on then it drives perfectly.
What i have tried :
Took it to a honda mechanic - said it's a faulty dizzy.
Checked ecu codes ( dash light method ) - threw codes 8 (Top Dead Centre Sensor) & 15 (Ignition output signal).
Replaced the dizzy with another used one - worked fine for a week and same problem.
I cleared the ecu codes and again after the CEL went on again it threw codes 8 and 15.
What could cause such issue? Possibility is that the used dizzy was also faulty but if the problem is being caused by something else i don't want to buy a new dizzy and have the same exact problem. Thank you :awais:
Get a FSM and follow the trouble shooting for the codes
Del Sol
Can you please tell me the name of the manual which includes ecu code troubleshooting?
Mine doesn't include them i guess?
