1 - 9 of 9 Posts
I'm looking for a cam gear for my d16z6 that I'm building and and noticed that my cam gear was messed up I'm not going all out with this... any suggestions oem cam gear or aftermarket
I have a big burly golden eagle one on my z6 head. I wouldn't exactly recommend any new fancy snowflake looking ones tho. I've seen them crack before.
D-series SoCal Division
93' dx hatchback
Do not get a aftermarket adjustable cam gear if you don't know how to degree a camshaft.
If your running stock cam, a oem D16Z6 gear will be fine.
If your going aftermarket these are the one's that I would perches, in this order from favorite on.
1. Golden Eagle
2. AEM 3 bolt (not the 5 bolt)
3. Edelbrock (if you can find one)
4. Skunk 2
When you said the gear's messed up, please explain.
likely the best adjustable cam gear there was....
Every SOHC D series from 89 to 95 uses the same cam gear. It wont be hard to find one, somewhere.
Bring a box cutter and a 12mm to the junk yard, should take 5 mins to pull. Loosen the cam gear bolt first, then cut the belt. :)
1992 Civic DX Hatch
I like OEM parts unless you just need an adjustable one.
1 - 9 of 9 Posts
