1 - 9 of 9 Posts
Honda
Issue: does anyone know of a swap or company that manufacturers at stock or up to .75 compression Over stock piston.? Criteria of the piston that I'm looking for:
75mm bore, coated skirts, floating wrist pins with clips,
And is not ridiculously priced..
Thanks for any help in advance..
1995 civic lx
Swap shouldn't be difficult. But might have to to some research on them. I could b wrong but i think vitera makes something you coud use. Just give em the specs and they ship. Hope this helps if im correct that is. Lol
Honda
I have been all over the Net looking for the pistons I desire. At this point I am having No Luck trying to find them.
so you've search vitara and are still not happy? time to call a company that makes pistons and have them make you some.
Love the Civic
Found nippons, 75mm, fits z6's, for $149........
look into the p29 pistons, they are a little bit of a boost in compression and can be found pretty cheap.
I dislike P29 pistons.
Find a set of PG6 pistons.
P29s give higher static compression, but are not optimal for our small bore'd chambers
1 - 9 of 9 Posts
