1 - 10 of 10 Posts
88 ED6
Alright, I had installed a Hayame cam gear, and noticed the lines were a little off, so I just aligned the two opposite parallel lines. Afterwards, the car didn't start. I noticed, when compared with my B1 engine, that the keyway was facing upwards on my stock B1, and with the Hayame cam bear in a B-VTEC, the keyway is facing down. Could it be the timing is 180 degrees off? I can't compare it with the stock cam gear because I lost it.
88 ED6
Discussion Starter · #8 ·
Snap, didn't work. I just noticed something too, before and after switching the cam around, setting the cam timing, etc., every time you hear a "pop" from combustion; it's always on the intake stroke(smoke comes out when you open the throttle after the pop).
88 ED6
Discussion Starter · #10 ·
I meant the timing. But no matter what I did with the distributor or timing, it would still fire during the intake stroke. I was thinking the distributor might be off, but it goes in one way and I double checked the firing order.
1 - 10 of 10 Posts
