1 - 9 of 9 Posts
OK the problem is when i first start my car (cold) it doesnt want to stay running it will just idle for 3-5 secs then die i can keep it running and once it gets a little warm it stays running and idles fine sounds like its missing slightly only when cold does it do that when its all the way warm it fires right up everytime.
i have
Adjusted valves
checked timing atleast 20 times
replaced Dizzy,plugs,wires,cap and rotor with all OEM parts
compression test
screwed in the with thing in the fast idle thermo valve
checked firing order
checked fuel pressure
had the injectors cleaned
checked grounds
gapped plugs to 26 (boosted on 22psi)
iam lost any helpful info is appreciated
Also forgot to mention that it backfires after it gets up to operating temp but does not backfire when cold like when i rev it up it backfires and sounds like a shotgun lol but when its cold it will not backfire at all
No CEL's and yes tuned on ECtune, it started like 3 days after it was tuned started by not wanting to start figured out that problem was the fpr so i replaced that then it just started backfiring when downshifting and has gone downhill from there
get a fuel pressure gauge and see what the fuel pressure is doing.
1 - 9 of 9 Posts
