1 - 4 of 4 Posts
okay guys i finally got my timing right it ended up being that all i had to do was the valve lash cause they were to tight and left the valves open on piston 3 and 4 thats why it would not start fixed it and it started right away. thanks for the help guys... but now i have another issue when i take of the care moves slow after six second then it catches speed and it go's it also does the same in reverse and turns of sometimes it also throwing a code and it says its the IAC but i check it and it read good voltage 13.5 but i might be reading it wrong i guess... why does the srs light also flashes when the engine light flashes any help would be great do you guys still think my timing is a little off
97 EJ6 boosted D16Z6
Did you check for vacuum leak?
Do you have a timing gun?
1 - 4 of 4 Posts
