Which Boost controller is accurate and the best you would choose?
  • Hallman
    Votes: 5 45.5%
  • Turbo Smart
    Votes: 4 36.4%
  • Turbo Xs
    Votes: 1 9.1%
  • Hallman Pro
    Votes: 1 9.1%
  • Total voters
    11
1 - 20 of 22 Posts
Wanting to shoot 300-350 HP, Need advice on what boost controller is accurate to use? I was gonna go with a electronic one but a manual one is cheaper and im on a low budget.
PLEASE ANSWER THE POLL!!!
Heres my build-
Head- BRAND NEW OEM HONDA GASKETS
Ported and polished
Supertech Valve Springs and Retainers
Gasket matched
5 angle valve job
Bisimoto Stage 3 Camshaft N/a
Bisimoto Cam gear
Skunk 2 Pro Series intake manifold
B16 Throttle body
Brand new Arp headstuds
Aem Fuel pressure regulator
Blox fuel pressure gauge
Bottom End-
Ycp Vitara Pistons, 7:5:1 Low compression
Eagle H Beam Rods
Golden eagle block guard
Ported z6 Pump, idle is 25 psi, (good oil pressure )
Tapped oil pan
Innovative 75a Motor mounts, very stiff
ACL race bearings
Trans-
S40 ex trans
5800Miles on Xtd stage 3 clutch
7lbs flywheel
5 Speed Manual
Short shifter
92 Civic Hatch
Have you considered the AEM UEGO Boost controller?
its what I use. Works good, has many features, just needs some getting used to
but its also 200+ dollars.
'99 Honda Civic Ex
I have Greddy's Profec B digital boost controller. It works great, but does take time to get used to like the AEM UEGO(like a5hatch said). But once you get the values dialed in, it's dead on everytime. I have never touch it since the tune, except to turn from low to high boost. Haven't messed much with what you had on the poll. Hope it helps.
too expensive :(
1991 Honda CRX
My other route was getting a Corsport electronic boost solenoid and having to solder in a PWM Ecu component in my hondata. Is that better??
That's your best option. Using S300? Just get he boost solenoid $80, PWM component $10 and you will have full boost control, boost by gear, good stuff:bigok:
Jeep wrangler DD
^^ exactly. If your using s300, just buy a boost solenoid for under 100 bucks and be done. Then you have boost by gear options, ect ect. You will never have to upgrade from that set up. We're using it on four of the outlaw sfwd cars here in utah that are 900-1000+HP
Hi hater!
Discussion Starter #20
1 - 20 of 22 Posts
