1 - 14 of 14 Posts
http://www.hmotorsonline.com/s...30018
is this motor a D16A6? why do they call it the sohc zc? How much power does this motor output? Can you swap the cylinder head for a vtec one (z6 head)?
Would this motor with a z6 head and si tranny be a decent combo?
-thanks!
1990 CRX DX
D16A6 is a USDM 88-91 SI engine 118hp , its called a ZC in Japan available in DOHC OR SOHC and yes you cen put a vtec head on it
Thanks for the quick answer! Couple more questions; Is the bottom end the same as the d16 usdm ones? as in rods, pistons, crank etc?
Once i put a vtec head on it would it run just as good as a d16z6?
1990 CRX DX
well i know that the DOHC ZC engine uses diff pistons , they are dome-tops, you can use them in a D16 block , but yes the A6 and SOHC ZC are identical, just has a little better cam like ryan said
REP ME !
my dick looks different depending on the flash used.......
Likely I'm one of the few if ONLY people to pick out the fuel pump lobe.........
RIP Earl Laskey
1 - 14 of 14 Posts
