i was debating on going all motor and not spend much but then at the same time wanted to go turbo.........
so for All-Motor whats the best set-up that i can go.......
and how about Turbo
DB2, EM1, EG6
if ur going all motor route - probaly be better off swaping the b series in there....
If want to go turbo route - just get a good turbo kit from go-autoworks and get er tuned with your D series...Perfer D16Z6 or Y8 block...
See above...
Yeah, with the amount of money you'd use to have a "useful" all-motor sohc...you could've swapped or turbo'd it. Now, if you consider all-motor with just bolt-ons "useful", then have at it!
why did you bump this thread?
the answer is in the sticky as far as NA build goes, along with many many threads in the NA section.
i was hoping that you would have learned form my post to look at the stickies in each sub-section of the forum. since there is also a huge sticky in the FI section. i did not post the link, cause again i was hoping you would be learning not just asking.
