I can possibly buy a 1992 VX civic hatch shell for roughly 750$ I am curious on what it would take to swap anything in it preferably a SOHC Vtec, I am on a very low budget like 1300$
There is a d16y8 engine that is pulled apart for $350 but no ECU or intake, and I can call someone else about a d16Z6 with no crank I believe, Ill keep posting when I can contact the d16z6 owner.
or just any other swap DOHC ZC would be nice too, just need some wise advice.
Any advice would be nice.
93 dx + 92 lx
Dude if u have that much, jdm d15b non vtec swap is like 700$ locally and will last for years.
Stock jdm power peak was 6800, so at stock p06 fuel cut you are just hitting power peak. Chipped ecu and a tune? 500$ itll pull maaaaad bruh. And theres ur budget.
Someone might chime in about using a p28 vtec ecu and ignoring the cel but I haven't ever done that so I'll leave that to anyone that has.
But now that I'm chipped up, swapping intake manifolds and tuning to a 7200 cut I expect to be as fast or faster than an ex on a smaller motor, without vtec.
Fwiw a jdm timing cover makes ur engine bay at least 20% cooler
Speaking of d15b... I have a d15b2 block with a delsol vtec head... What ecu should I be using?
match the ecu to the head
