i got a z6 block from a local guy and the crank is sheared off at the pulley and i was wonderin what cranks was interchangable any insight will be helpful thanks in advanced :lol:
Formerly weebeastie
Hollander Yard Management System says:
That any D16 crankshaft from 89-95 will fit in your z6. That means you can use a D16z6 or D16a6 crankshaft without any problems. Hope that helps. PM me and I'll see if I can locate you a good crank.
racist-bigot-sexist-homophob
Not all cranks are created equal. You'll need to check main and rod bearing clearances with whatever crank you decide to use.
I would be weary of a block that had the snout broke off the crank.
