1 - 20 of 57 Posts
1990 Honda Civic 3DR
Just joined, frequent reader. Please be patient as this is a DD and 1 of 2 projects I am slowly working on, I will add more pics and info as I upgrade. I hope it's worth the look, and please don't make negative comments if you don't like it (you don't have to, your car probably doesn't float my boat either...lol).
I have a 1990 Honda Civic STD (Canada Manuf.). It has an OBD1 D15B VTEC with a 93 Del Sol Si 5spd, Rywire Harness to a P28 Chipped w/ P08 base, F&F Type1, Function7 RLCA, OEM 19MM Front Sway, OEM 15MM Rear Sway (Prethreaded, thank you Canada!), wheels, exhaust, and intake are from eBay (flame on, :gayfight2: Ha).
Things I've Changed/Replaced/Repaired/Trashed:
1991 Civic Sedan LX Cluster (Changed over factory Speedo/Odo)
Digital Clock
ED/EF/EE Si Throttle Cable
Rear Hatch Light
Removed rear carpeting from seats due to mold
Red Rear Center Garnish
Removed A/C Components (minus control panel, compressor wasn't connected when purchased)
Wrinkle Black Valve Cover with Brushed Letters (DIY)
Screwed on a VW Jetta Lip (Smaller Version)
2500K Hi Beams (NON HID)
4300K Lo Beams (HID)
Plans for the car:
Convert to 88-89 front bumper (Has 89 Rear)
Remove Side Moldings and Fill Holes
J's Style Wing (TNA 1-Piece)
Repaint OE Color
Thermal R&D CL Catback or Tanabe Medalion
4-1 Header
Headwork for Level 2 or 3 cam (And supporting valvetrain and cam) - Need advice and tech help for many questions.
Rebuild bottom end (Stock)
Tune
Rear Disc Conversion (Alread have 40/40 Prop, Rear arm froms 98 Integra LS)
Overall, wanting to build a fun little DD/Weekend Spirited Driver. Looking to get about 150+whp N/A. - Need advice and tech help for many questions.
My car...or my truck
Nice car, let's see some more pics! And welcome to dso. My friend had a D15B in his 91 Si, was spunky little car
another tampa member, welcome.
Day 1:
Came with D15B7 Block and Head, Everything else was OE:
Old Motor Out:
First Time Attempting a small wire tuck before the D15BV went in:
D15BV in still not 100% at this point:
LX Cluster and D15BV Wired Up:
Some wrinkle black prior to NGK wires:
wonder how small our circle is lol. where abouts you live?
Brandon/Riverview Area
on the other side of town. gotcha. we have a few members out that way, wouldn't be surprised in the least if you didn't already know them.
biggiebert and mr.fodo.
I don't get out and socialize much anyore. I've been working late nights 6 days a week. I've probably seen cars around and would probably recognize those before names. lol
Lurking... ಠ_ಠ In Your Thread
ES1 Civic
Welcome. Looks like youre (one of the few) new but well versed in what youre doing. We like this.
I try, I'm basically trying to build a car to prove a power to weight ratio argument... And I'm honestly tired of the K/B/H hype these days. After taking a few physics classes in college, the concept of reducing rotational mass plus already having less overall work to perform, a D15/16 just seemed fitting for this car.
Love the Civic
Welcome to DSO. I am interested in your Infinity and Civic builds equally. Please post more of both. We are into more then just D series engines, and cars for that matter. It is more about the process and thinking involved. No more niceties. Moar pics!
:popcorn:
Discussion Starter #15 (Edited)
Ok... Here's a little about my other project.
2005 Infiniti G35 Sedan S. 3.5L 6Spd.
Spec Stage 2+ Clutch
ACT StreetLite FW
3.916 Nissan OE Final Drive w/ VLSD
LiteWeight Crank Pulley w/ Idler Delete
Takeda Intake
M2 Shorty Headers (Stillen Reps), Stillen HFCs, Borla TrueDual Exhaust
MREV2 (P&P Lower Intake) w/ 3/8" Plenum Spacer
rareJDM Engine Harness Cover
UpRev Tune by Fever Racing (Z-Fever) (271whp/249wtq)
Tein Basic Coilovers for 350Z/Coupe (1" Lower than sedan)
MotorDyne F&R Sway Bars w/ PU Bushings
SPC F&R Camber/Toe Kits
Varrstoen F:19x9.5" +20 245/35R19 (Offset with 5mm spacer)
R:19x10" +25 245/35R19 (Offset with 5mm spacer)
OE Replica Front Sport Lip
OE Nissan V35 Skyline Window Visors
OE Nissan V35 Skyline Rear Taillights
OE Nissan V35 Clear Bump Side Markers (wired to work w/ turn signals)
Polished Titanium Shift Knob
Nardi 350MM Woodgrain w/ NRG Hub & QR (Black)
Clutch:
Final Drive Ring & Pinion (2nd Pic Rear End Out):
Shift Knob:
Corner Lightes (Also Painted Bezel for Headlamps):
V35 Tails, 03/04 Modified Reverse Lights:
Stance for yo pants (Poor Honda Key):
Love the Civic
I like the G35 always have but not in my heel house, I am a sedan fan. Wanted to make a gt350 four door for a bit now, I like what you did here so far. Thanks for the share.
when you went to zfever, was it on fowler or clark? I used to work next door to the shop on clark. fucking loved showing up to work and watching the badass nismo cars, turbo cars, parts and the 2 r33's. made my day. still drive by every chance I get
1 - 20 of 57 Posts
