1 - 20 of 81 Posts
DOHCDX said:
my buddies', all on street tires:
[email protected]
95 DX hatch, d16z6 swap, gutted, 2120lbs w/driver
DC sports 4-2-1, AEM Cai, catback exhaust
[email protected]
90 DX hatch, d16y7 swap, gutted, 2040lbs w/driver
4-2-1 header, straight pipe, short ram intake
good setups
here is mine:
port and polished head, milled.06
i/h/e
racing crank pulley
crower stage 2 cam with skunk 2 sproket
138 hp(this is only a BASE run ,no tunning what so ever),
[email protected](that time is with out the cam and a smoking clutch)
H
1995 Del Sol Si
9.5 1/8 (which i think is high 14's in the 1/4)
D16Z6: 55 shot, ractive intake and muffler, HP 4 to 1 headers, 2.25 piping from the cat back, port and polished head that was shaved a little, denso iridiums, street tires, a warn stock clutch with 110,000 miles on it, and the timing was probably off( since my non mechanic ass did the timing on it)
Currently the motor is at a performance/machine shop gettin some goodies and basically a full rebuild. SRP pistons and rings(.002 overbore and 10.5 to 1 compression) and Eagle rods. For the head I'm going with a Zex Cam 59300, hayame cam gear, zex valve springs. I'm replacing the HP headers and going with DC's 4 to 1. I haven't yet figured out what chip/ecu program or clutch I want to go with. I'll up my shot to a 100 shot once I upgrade my fuel. Last but not least a new tire and wheel package(i'm rollin on stockers). If there's anything I'm forgetting to upgrade plz let me know(like pulleys, but i heard they don't do shit, or upgrading the spark/ignition). My goal is to run 12's in a streetable, full interior, single cam sol.
Any suggestions???
A
currently
1991 crx hf
d15b2
custom head design
custom cam grind
ferrea valves 3mm oversized
crower springs and retainers
si intake mani(ported)
chipped ecu
jdm t28 a/r .80 and .63 turbine
vortech 12:1 fmu
si/zc hybrid tranny
quaife
as of now i have no times with the turbo n/a [email protected]
91 crx si
z6 block
y8 head shaved 60/1000's
y8 intake manifold
1st gen b16 t-body
96 h23 injectors
vortec fpr
DC 4-2-1 header (as of today reactive 4-1)
reactive cold air intake
2 1/4 mandrel exhaust
pwo ecu with spoon program
some weight reduction (full interior)
16 c8's on kumho 712's
and at sea level (65 deg f)
3 passes of 14.6 @ 94mph
95 CIVIC EX COUPE
stock gsr throttle body
SheepDog full exhaust(header back - no cat)
re-chiped p-28
ballenced bottom end
lightened flywheel
DC 4 - 1 headers
Stock 14"rims and tires
*** i got no traction *** :x
[email protected] :?
[email protected]
Thats with street tires stock clutch
d16y8
jg TB
milled 30/3 angle
DC 421 header
shorty intake
jg 85vt35 cam
holley fuel pump
2.25 exhaust/no cat/ ultraflo
45 shot NOS
new stuff untested:
ported head
RC bal/blueprinted injectors
ported IM
Apexi 4 to 1 header
OBD 2 to 1 conv. with p28
Chasing low thirteens!!!
M
[email protected] kph (around 90 mph)
1993 Honda Civic ESi
This was way back January, the only time we timed it. Since that time I got more added, or replaced some with better ones (filter and intake specifically). And when we timed it 4 people were in the car (me, my bestfriend, and his brother and sister), so the time might actually be faster if we're only 2.
Mods then:
Simota filter and short ram
5 Star high tension wires
Splitfire sparkplugs
custom (4" tip) exhaust
No 4-1 header and 2" pipings yet, and since then I have sold the Simota filter and intake for a K&N filter and Iceman short ram (well, it's really part of a CAI, but I bought it second hand and the extension's missing), plus recently I installed AEM pulleys and cam gear, as well as have a high lift, high duration cam. So I would think the time's improved since then. Tires are still stock (stock 13s).
M
It's not a race--we just timed it on a dark stretch of road, and we'd do it again, but it's a quite busy road so I decided not to risk it. I'll have to time it again and see how it improved.
You timed it with a G TEC?.......they are close but not as presice as
at a sanctioned drag strip.
A
i agree. my gtech even though the weight i inputed was correct(truck scale) and the gtec accelerometers calibrated it still was off by .2...isnt bad but not accurate.
U
95 EX coupe
AEM CAI
DC 4-2-1 Header
BBK 62mm TB
2.25in. cat back exhaust
no rear seats, gutted trunk
Kuhmo 711's @ 30psi - I don't like these tires, but they were cheap :p
15.7xx at 87.xmph (don't have the time slips in front of me)
That's with my lackluster 2.3 60ft time - the tires suck, and I furthermore can't drive :lol:
I'll try it again in a month or two with less weight and some boost :)
M
Well, what we did was more like gauge how the car would go rather than get an accurate reading. Yes, there's a +/- differnce of around .2, so it could be greater or lesser than that, but as it is it's not a bad time, considering the mods placed then.
Civic ESI (si) D16Z6
with supersprint header and catback
shortramfilter
fidenza alu flywheel
act clutch
B16a2 TB
25 pci streettires goodyear (fairgrip)
2410 LBS/ 1090-1100KG
15,8x @ dont know but somthing like 86-88 MPH (my normal speed this place only tells the time ! :(
setup:jdm zc sohc vtec 1.6l
:aem intake
:jg bored tb
:denso iridium plugs
:accel 8.5 mm plug wires
:aem fpr
:aem fuel rail
:2.5" cat back custom made
:2.5" straight through muff
:landspeed racing powercore high flow cat!
:energy susp. motor mounts, shift linkage bushings
:removed a/c, all interior except steering wheel, gas pedal , seat , including the tar shit under carpet.
:eibach sportline springs
:spc camber kit front and back
:rota sub-zero 15-6.5 flat black
:khumo 711's
:short throw shifter
:skunk dual weight shift knob
:ran a 16.3 at 89.5 mph after i put just the engine in.
:r/t .918, 60ft. 2.494 ,
:that was my first run on a drag strip in hallsville texas, I know it kinda sucked but i am building the car up fast as shit ,soon it will be under some extreme boost and have fully built internals, later
E
Discussion Starter #19
1850 pound 5th gen hatchcrap
175/70/13s @ 35 psi
D15b7 with I/H/Ls B pipe and a 89 CRX Si cam
DX tranny
2nd time down the strip ever
15.5 @ 88
10.0 1/8th
I know I could have gone faster. 2.492 60 footer. :?
Now the car has a Z6 in real good shape. I'm too lazy to go back.
man dont laugh i did not know what the hell i was doing and that was w/ the motor out of the crate no mods at all. I still suck, I am going back this weekend to see if i cant pull at least a high 15. what do you guys think i should do to improve , i think my 60' times are eaten' my ass up. i launched the first time w/ 35lbs. of tire press. front and back i know put the front down to 22-25lbs. and i took off from 1500 rpms, second run my trap speed was even higher w/ a lower et than the run i posted, i guess if i can get outta' the hole quicker than it seems that my speed is reallypicking upafter 1/8 mile, I dont know somebody give a brother some sugg. :holla:
1 - 20 of 81 Posts
