Alright guys well my waste gate currently has a 5psi spring in it so I am looking to buy a spring that will allow me to run higher boost. Took the waste gate off to measure but got 1.25 inches (31.75 mm)???? It is a cheap xs power one. I googled but didn't come up with anything that size. Anybody know what size it is or where I can get springs for it?
Thanks
Poop Sock
not sure about sizes but I know most people gauge them based on the color of the spring. like a yellow, blue, green spring would be X amount of psi.
maybe google, "8psi xspower wastegate sping." or somethink like that.
Thanks for the responses guys. I'll def be checking in to using tial springs.
Edit: yes it is a tial knockoff. Identical to he one on the
Link
Yah the wastegate above works with a Tial spring, and theres another very similar knockoff WG that will accept a Tial spring as well.
Dont expect it to be exactly the same boost level though because it may be compressing the spring more or less, so the cracking pressure will be different.
IMO a 8 psi spring is great because youd probably never need to run any less boost than that and you can turn it up quite a bit with a boost controller.
