1 - 20 of 22 Posts
Ok guys im still giving the finishing touches to my car, but whats wondering how much power Can I spect from my 92 Hatchback (d16z6 turbo) that now has a P28 chipped by Xenocron. It has a base map acording to the expesification that I porvided Xenocron!!
Or I guess what numbers did you guys made with just a chipped ecu without tunning?
Of course my car will be tune but wanted to have an idea of what to expect.
10000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 HP. lol how the fuck are we suppesed to know? whats your set up? basemaps are only designed to get u to a tuner.
Dude you should know better... You should have realized posting no info about your setup and asking what type of numbers you are going to make on a basemap would get you flamed...
most stock turbo d's make between 150whp-210whp...
LOL, dammmmmmmmmmmmmmm I should have knownnnnnnnnnnnn!! My bad guys, I was tired alright LOL.
Anyway here it goes.
My turbo is a T3/TO4E 50 trim w .63 A/R
550cc tunner toys injectors
Walbro 255 fuel pump
phenixturbo intercooler.
Tial BOV and Wastegate
OMNI POWER 4 bar DIRECT FACTORY REPLACEMENT map sensors
AEM fuel rail and regulator
Edelbrock intake manifold
GSR throttle body
ARP head Studs
Cometic gasket
vitara pistons
Eagle rods
12 LSD ACT flywheel
LCD clutch kit
Auto Works Downpipe and downtube
3" exhaust
There you have it guys!!
I just wanted to know what can I expect with my set up and a base Map from Xenocron or from any place that know what they doing. I KNOW I STILL NEED TUNNING, The D16Z6 makes 135hp from stock, right?? Add my turbo set up and a basemap from Xenocron and now what should be my HP now? I guess that is the question that I wanted to know.
Thank you guys.
D16z6 make 125HP, not 135HP. But giving you a number is just still a number. It's better to know you are tune than how much power you are making or going to make.
ya your untuned HP is useless anyway caseu u cant really beat on your car untill it is tuned anyway. as it stands u have about maybe 140-150 useable HP. any extra beating on it in the higer rpms is unsafe for your motor. again that number is only there to make u happy so u have a number to play with. with that set up u will see 300+ easy on a good tune some boost.
300+ on a stock d? really?
:bigugh:
From left to the right ........ READ!!!!!!!!
GSR throttle body
ARP head Studs
Cometic gasket
vitara pistons
Eagle rods
12 LSD ACT flywheel
LCD clutch kit
3" exhaust
I'd have to agree on the reading thing... importheaven, it says in his set up:
vitara pistons
Eagle rods
mrfunktastic is right. This set up should produce 300+hp once it's tuned.
Yeah fuck you guys it was 1am and I was checking the forums in between homework.. :haha:
OP What thickness cometic did you decide to go with?
d-series Member
lol flames op, only to be flamed himself... beautiful irony hahaha ;)
op, you still didnt tell what psi you'll be running...
Friend of the D
It's all good. I got caught not reading the original post on a thread just the other day.
That is pretty good. I was pretty much figuring the OP was going to let this thing rip.... I sure would ;)
I think Im gonna need bigger injectors, don't know if 300 is possible with my tunner toys 550cc injectors. Anybody know if it is possible?
Friend of the D
The 550's should be good until 350hp or so. Gas quality, your tune's quality, and your build will all start to come into play before then.
insert user title here
you can get to around 300 hp with 450cc injectors so you should be all set with 550 injectors.
if your goal is 300 hp you should still be able to hit 300 with a .48 exhaust while spooling faster.
lmaooooooooo
:skull:
You can make 210hp peak from the basemap but that doesn't mean the basemap is going to give you a good powerband. I used to rip my motor on base map a few years back and when I finally decide to get it tune I always wondering why I drove it untune from the first place.
Discussion Starter #19
Thanks guys, I will probably have it tune that way I will see the full potential of my engine and then I will learn and take from there. Now I have to decide in the management that I will use and what feature it has (check my other thread, LOL).
whats your opinion of the xenocron basemap? did it start well? is it running smooth? do u notice your air fuel ratios being really high or really low? i am probabaly gonna use his maps to get me started i just want to know what they are like.
1 - 20 of 22 Posts
