1 - 7 of 7 Posts
Hello if someone can help me it would be great. When im driving and go to put it in third it grinds bad and grinds high RPM to wut could be the problem and how can i fix it
D-Series Post Be-itch... gimme gimme gimme
Read my sig.... lmao
Really, what causes grinds is the missalignment of your shift forks... causing the gear to go in wrong... this can be caused by 1.trying to shift too fast, 2. old tranny fluid, 3. bad rear motor mount, 4. bent shift fork, 5. bad syncro, 6. bent shift arm, in order of likelyhood.
:werd: and if you install the stickers that come with them, you get 35.71 HP. It has to be true, cause there is a decimal... lmao.
1 - 7 of 7 Posts
