89 Crx
Ok, turns out i just melted a piston. Not good news.
I have...
94-01 integra rear mount bracket, good for swapping into EG's 45
94-01 Drivers side mount 15
94-01 Tranny mount 15
94-01 Lower tranny mount (that mounts to the frame rail)10
94-01 Lower drivers side mount/ac bracket (mounts to the frame rail) 10
94-01 LS Throttle cable 15
B18b1 LS OEM clutch/Flywheel/Bolts, Good condition. 70obo
B18b1 Alternator x2 35 each
B18b1 Alternator Brackets 10
B18b1 crank pulley/bolt 15
B18b1 OEM cams, 3 sets. 15 a set
B18b1 Oil pan 30
B18b1 pistons/rods. x3 45 for all, 15 each
B18b1 Thermostat housing/coolant tube 10
B18b1 waterpump, GC 10
B18b1 Timing belt, 500 miles 10
B18b1 Wire harness, obd2(a?) It will plug into an EG, and has obd2 injector plugs and dizzy plugs. Good if you have an obd2 40
B18b1 Iacv x3 20 each
B18a1 IACV 20
B18b1 COMPLETE oem valvetrain (springs, retainers, keepers) 25
B18b1 rocker arm set 20
B18b1 Oil pump, Inspected and blueprinted. 15
B18 Knock sensor. 15
ECU's
Chipped P06 converted to Vtec. 100. I can make and supply you with a basemap for no extra charge
Stock Po5 Manual. 60
USDM p30, CANNOT BE CHIPPED (clad is messed up around socket) but still functions PERFECTLY as a stock P30. 100
I will take trades. Im looking for an LS block/shortblock/bare block with mains/long block... Large intercooler.... B-series stage 3+ hydro clutch.... forged turbo pistons. Pretty open.
AIM Havoc340
Email [email protected]
Live,love,laugh,be real
07' Odyssey 07'Magnum
7:00 pm bump... :)
friday the 9th bump...
FAMILY MEMBER #316
d16rice is looking for a b series swap...just fyi
