1 - 20 of 21 Posts
My friend is sworn up and down you can "chip" or "mod" a Honda OBD2 ECU.
From all of what I have read and seen this is not possible... Hence the need for OBD2a/b -> OBD1 conversion harnesses.
Anyone want to back me up??
D
Lets put it like this if that was even possible why would they even invent an OBD2 - OBD1 jumper harness?! "NUFF SAID"
sub-sponsor
93 civic
a obd2 can be modded just not a lot of people tune them, obd1 is hell of a lot simpler
Yeah.... It's just a fact of you cant get nearly close to getting the features from an OBD2 that you can get from an OBD1. You are limited to the stock program's limits in an OBD2 vs. an OBD1.
He believes me now.
D
Yeah at this point in time if you want to do anything you convert to OBD1 it. But that will eventually change of course LOL
He just asked if you could use a OBD1 on an iVTEC motor...
sub-sponsor
93 civic
hmmm dont think so. but dont know for sure
Hell, I woulda thought if programming OBD2 was like any other car it would be a standalone unit you can plug in, get performance and boom your done.... but I havent seen anything like it on the market..... It will probably be a long time before it happens too.
D16Z6TURBO said:
If i-vtec is OBD2 couldnt you just use a jumper harness?
iVTEC is very complex compared to "is coolant ok, is speed ok, is oil pressure ok, is RPM ok? ok, enable solenoid".
I think it would be possible to write ecu code to read sensors and make adjustments in certain ways to make it function properly... but it's very complex compared to VTEC-E or others.
sub-sponsor
93 civic
its not the same, the motor is very diffrent from say a b18c
Agreed, especially because it has more sensors that do special things for the iVTEC then any other motor.
D
Yeah I dont know much about it but a buddy that just graduated Wyotech said even there they taught ya not to mess with OBD2 if ya didnt have to
Check out the latest Honda-Tuning, they have some interesting stuff on i-VTEC. The cam phasing is accomplished by a mechanical system in the cam gear itself - the mechanical components determine the cam phasing rather than the ECU. So, in a sense, the ECU DOES only turn the solenoid on and off for the wild cam.
can't run obd1 ecu on the new i-vtec motors... the obd2 ecu (which is different from all the older obd2 ecus) can be reflashed though.
1 - 20 of 21 Posts
