1 - 3 of 3 Posts
D
I just did a tranny swap in my del sol ...auto to manual conversion...however i still have some probs....When i am in first and taking off, i hear a clicking noise with tranny, as i speed up it gets lounder. Now remember i just did a d15b7 tranny swap to a D16z6-zc and the mounts didnt line up.. i had to move and re-weld the mounts (which sucked). I dont know if that is the prob but i dont see how it would only affect first gear.. please help me....cuz i just spent 1200 dollars on two tranny...(The first one was bad!) I really dont want to spend more money..unless i have to...maybe it is something i can fix...
Oh yeah..the other probs....after i did the swap..my check engine light wont go off...my reverse lights arent wired to the new comp...(or however you have to wire them)and my comp i have is a chipped p28!...
Any info would greatly be appreciated....
I have a bunch of stuff i left over to from my engine swap..and my tranny swap...Let me know if you need or want anything...i am sure we can work something out....(p28 auto computer, starter..distributor, d16z6 head, mounts..flywheel,and more stuff )you get the picture...let me know what i can do for you. ...
I need your help Transzex-Mista bone
Thanks again...i will get pics and stats adn stuff for my car...as soon as i get it fixed...
94 del sol si
d16z6-d15b7
chipped and loving it.
DONT LEAVE ME HANGIN!
you did what?????????
No need to weld in new mounts.............
What is the codes????????
Plug the reverse light switch in.......
I'm betting most of the noise is from a misaligned engine mount.
D
the reverse light is switch is plugged in....I might be wrong ...but i thought you had to rewire it to the automatic gear position switch.. because i still have that left in there by the shifter....
for some reason...the side tranny mount was bout 2 1/2 inches off..and i tryed everthing i could to line the mount up...but the engine adn the tranny werent moving...
Maybe i was sold the wrong tranny...but i got it to work..and i didnt think i had to move the mounts either....but i did... i really like how my tranny is running ...with the exeption of the first gear sounds.....with the chipped comp.....i am running 4000 rpm in 5th at 75 mph...adn when i speed up to 90 or 100 or more...the rpms only go up to 45-4600...and the throttle response is great.. is this normal...or is this the result of a wrong tranny in my car???
THE CODES ARE ---- S20-1570558---By the block and trany bell housing
Y4B P20-- by the tranny mount...
Please Transzex.....what was i sold..?? and is this compatible with my Del Sol d16z6-zc
Thanks to any replies.....i have lots of stuff for sale....let me know what you want.
1 - 3 of 3 Posts
