1 - 20 of 33 Posts
so im starting my first engine build ..
first of my setup .. om going for boost..and running on Ethanol
D16A6 block bored to 75.5 ( notching ahead)
D16Z6 head
Supertech pistons
supertech springs,retainers,valveguides,
Cat H-beam rods
skunk 2 intake
some pics as far as have come any tip on anything is welcome !
fiirst the car..
Well?
damn didnt know supertech made pistons, just read up on them, they seem pretty damn sweet. what turbo you going with
well dont know what turbo etc im gonna use.. i just want to finish the engine and get my fuel and egnition managesystem first..
Lifes short, drive fast!
damn, those rods are going to need alot of notching
thats what I was thinking, those bastards are thick! Eagles require around 1/4" of notching, it wouldnt surprise me if you were in the 3/8-1/2" range with those...
well started the notching process yesterday .. and well it wasnt that hard.. and i tested the first cylinder and it went around.,, im soo thrilled ! :D thanks everyone that has answerd my questions.. will upload pics soon !
the notching was about im from sweden so i will write in Mm.. :p about 8 mm down the cylinder and about 9-10 mm in to the block =) the brand on the beams are " cat "
lol did u check the girdle? is there a girdle on a a6?
yeah gurdle going to be notched to.. damn mu "dremel" went up in flames when i did the final touch on the block.. go to the shop and get me a new one tomorrow ! any one that has a comment on what Ex manifold im gonna use ?? i want a stainless one .. i like this one ?
Build looks good so far, those rods look beefy. As for the manifold, those will crack over time, they usually end up in the garbage cause they crack so much.
Check out our website in sig for manifolds.
honda/firebird form.
obx manifold = fail to a nice build/block you have going on... dont cheap out.... now for the turbo, you can get away with an ebay 57trim with a restrictor...
Well?
x2
1 - 20 of 33 Posts
