1 - 17 of 17 Posts
I received my Crower Stage 2 cam and valvetrain and after having it installed,it bent 2 valves on the same cylinder while it was idling.
Now I am going to have the pistons pocekted "valve reliefs" but is this normal or has anyone else had the same problem?
1997 Honda Ballade
since ADsmith is offline I will fill in the blanks
D16A7 engine with D15B sohc vtec head
PM6 pistons, stock con rods (bottom end stock)
no clay must pay! :death:
mechanics :single fuck: this is why I DIY.
So....Non vtec pistons...From the A6,which has smaller valve reliefs than the D15B Vtec valves.
And a higher lift cam...
Where's Sherlock Holmes at?
1997 Honda Ballade
thats what I been trying to say!!
88-95 (block with pistons) with a 96-00 head will have valve reliefs issues!! even non vtec
racist-bigot-sexist-homophob
Thnaks for the response guys.Couple of suggestions and yes,I also wondered why it wasnt clayed to start off with.
Ok so timing is be looked at and valve relief.Anything else I need to know before I have have another headache?
1997 Honda Ballade
u should have kept the D15B pistons....
If he is going to cut valve reliefs its best to take out the pistons....
Then u should go new bearing and rings...etc...
Ya well,too late for that now man.If I do that then I might as well get 76mm pistons while I am at it
Reading this thread laughing his ass off.
x2 this is hillarious when it doesnt happend to you or anyone you know
what kind of clay is best to use to clay your engine?
:saddam:
that sucks balls bro...you should definetly check the shit before you start the engine specially having that setup...imagine the damage you could of caused in vtec :eek:sama:
im gonna have to go with
"the timing owned my ass for 500 please"
thats hillarious
this is the laugh meter::ekg:
1 - 17 of 17 Posts
