1 - 20 of 35 Posts
Here are a few phone pics of my new ride.
My mod list.
Engine:
D16z6 head complete rebuild by Cylinder Head Services
Stock port
New Skunk2 intake manifold
New Zex Stage 2 cam (59300)
New Supertech valve springs
New Supertech valves
OEM 60mm LS throttle body
New ARP headstuds
New OEM valve seals
New OEM retainers
New OEM valve keepers
New OEM headgasket
New OEM valve cover gaskets
New OEM cam seal
New OEM timing belt
New OEM timing belt tensioner
New OEM alternator belt
D16z6 block
New 75mm YCP vitara pistons
New Eagle rods with big bolts
New ACL main bearings
New ACL rod bearings
New OEM main seal
New OEM oil pan gasket
New OEM water pump
New OEM oil pump
New OEM oil pickup
New OEM main bolts
Drivetrain:
D16z6 tranny with 1st gen OBX LSD
New Action 2md clutch
New OEM axle seals (located on tranny)
OEM resurfaced flywheel
New Energy Suspension shifter stabilizers
Brake and Suspension:
GSR front brakes*
GSR rear sway bar/LCA's*
Strut bar welded into trunk*
Koni Yellows*
H&R Race springs*
Exhaust:
RRP 2.5 inch ECUTOUT for track and then connected to STOCK exhaust for quiet street drive
Turbo Setup:
Greddy 15G turbo
Greddy cast turbo manifold
Greddy cast elbow
Greddy downpipe
Ebay intercooler
Ebay SSQV BOV
Ebay intercooler piping
Hallman Pro MBC
Fuel Management and other MISC:
P28 with Neptune RTP (Less then 1,000 miles on RTP)
PLX wideband with gauge
New Motorola 2.5 bar map sensor
New Precision 780cc injectors
OEM resistor box
NEW Walbro 255LPH
Autometer Boost gauge
Autometer Oil pressure gauge
My plans are to get around 2k on the engine with this turbo then I will be purchasing a SpeedFactory Mini Ram Manifold.
I'm still trying to figure out what turbo???????? Any thoughts :)
shes a looker :)
as for a turbo cant go wrong with the bullseye 57trim :)
Very nice car. i love the clean interior. this makes me want to get my del sol ready for my engine but it would take more than my hatch
insert user title here
a 57 trim might be able to be pushed close to 500 hp
sc61 would do the job for sure but night be a bit overkill.
btw russ, it looks just like my old sol
Well?
o man i miss my captive del sol so bad. Please for the love of god put the aux. lights back in, i love them so much
Lurking... ಠ_ಠ In Your Thread
icanhaz?
russ did you get that car from evosol? he used to have a vitara delsol in spokane. i always wanted to meet up with that guy, but he was pretty busy with school
Discussion Starter #17 (Edited)
Thanks again everyone.
Yep this is his old car. I loved this car from the first time I saw it go down the track.
Evosol and his brother Y8pwrdEf on here both had/have some killer rides.
Their cuz is the one you did the build on this car. I was lucky enough to have the money to purchase it. This saved me a ton of time on doing the build, so all credit goes to Z the former owner. Hes a good kid!!!
I'm just so happy to have a turbo D16 again.:)
1 - 20 of 35 Posts
