List of what all is done to it at the moment:
Engine:
DOHC ZC
75.5mm Race Engineering/Wiseco Forged Pistons
Eagle Rods
GSR Throttle Body
OBD1 P29 Intake Manifold
AEM Fuel Rail/AN engine bay lines
B&M Regulator
Hiprofile 800cc Injectors
Cometic Head Gasket
King Bearings
B16A ARP Head studs
All New Honda OEM Gaskets/Seals/Sensors
OEM Valvetrain and cams
Powdercoated Wrinkle Black Valve Cover/Intake/Cam Gears done by yours truly.
Hasport 88A mounts
Wire Tuck/Battery relocated
Custom 2.5" exhaust with Dynomax muffler in rear, generic muffler in the middle and Catalytic Converter (yes real cat, I passed emissions in this car in March)
CXracing 1/2 Radiator
Transmission:
Si Cable Transmission with phantom grip LSD, will be rebuilding and installing Mfactory LSD this Summer.
ACT Xtreme Clutch with ACT Flywheel (12lbs IIRC)
Suspension:
Omni Power Coilovers (10Kg/mm in front and 12Kg/mm in rear)
PIC Rear Lower Control Arms
DA Rear Disc Brakes
Energy Suspension Bushings all around.
K-tuned Traction Bar
Interior:
Si Interior
Civic Si passenger seat and Scat Race Driver's seat
Prosport Gauges with one button heater
Roll Bar (Guess you would call it a 4-point now)
OBD1 converted on Neptune RTP (tuned by me)
Exterior:
Wings West Urethane Body Kit (thick rubber, stronger than stock or else I wouldn't of got it)
Summit Racing Orange Metallic paint
XXR 002 15" +38 offset
Turbo Setup:
HX35 Turbo
Custom Manifold with true twin scroll setup
Custom 2.5" intercooler piping
Custom Oil lines
Custom Downpipe
Go-autoworks Medium Intercooler
Turbonetics Raptor BOV
Tial 38mm Wastegate with 10psi spring
That's all I can think of off the top of my head. I basically did everything myself, I don't like other people working on my car so I had to learn how to do everything. Right now I street tuned it and drives great, starts getting into boost around 2500-3000rpm and full boost comes around 4500rpm, you gotta love divided housings
