1 - 9 of 9 Posts
Eg hatch
Hello guys, first post this is my first engine build. Looking for feedback.
76mm d16z6 block
P2P0 custom length rods.
ARP rod bolts
vitara 76mm pistons
.003" piston to wall clearance
ARP headstuds
ported z6 oil pump
ACL race series rod/main bearings
.0015" rod bearing clearance across all 4 (25ft,lbs)
.002" main bearing clearance across all 4 (20ft,lbs-45ft,lbs)
D16 z6 head
Ported and Polished
Crower springs
59300 comp cam
ported and polished d16y8 intake manifold
catch can setup
Balanced Rods
Balanced pistons
MicroPolished crank STD size
pump gas
PTE 5831 turbo
top mount
Tial wastegate
Tial blow off
treadstone intercooler
3 piece piping
1000cc bosh injectors
Aem fuel regulator
eddlebrock fuel rail
Aem wideband
ECT.....
Im looking to make high 300hp to low 400hp. My question is do i need the head to make that kinda power? Or can i sale it and use the funds elsewhere?
Also what clearances and torque specs did you guys run? is there anything i did wrong? just looking for some constructive criticism thanks...
Certified O.G.
A Shitbox
I have been out of the game a long time, but if memory serves me correct, 76mm on stock sleeves is stretching it thin. Looks like you have a nice set up though man, I want to see the car it's going into. This for a daily setup or a drag? My uneducated guess, drag.
Eg hatch
That's what it's going into.
95 eg coupe (cut)
Ya ive been hearing 76mm is pushing it but too late now lol.
i have a 75mm back up z6 block would just need rods.
as for my goal im aiming for high 400hp with the built head and high 300hp with a stock z6 head>.
why ask about torque specs?
RTFM, its free! might have to search something like ab0ve civic manual, but it is the tech manual you will want, the tech manual you will love, and the tech manual you will cry about if it disappears
Eg hatch
Discussion Starter · #8 ·
running a D16z6 transmission W/carbon synchros and m factory LSD.
Im asking about torque specs,because i keep ive seen people run oem spec 23ftlbs,arp 2000 spec 28ftlbs and ive also seen 48ftlbs. Thats why i dont know what i should run.
1 - 9 of 9 Posts
