what do you think??
  • AWESOME SETUP
    Votes: 12 24.0%
  • NICE CAR
    Votes: 22 44.0%
  • ITS ALRIGHT
    Votes: 10 20.0%
  • WHATEVER!!
    Votes: 6 12.0%
  • Total voters
    50
1 - 20 of 36 Posts
Hi,
Everyone I'm new to site. I love my d-series, everyone told me to b-series, but I wanted to be different. It feels good stomping the b-series guys and also of course the domestics. This is far from a mild build, but i want faster, so i have another block I am goin to sleeve and run e-85, if they will bring it back to oklahoma, bastards. A shop here in Oklahoma City has been making runs to texas to get e-85 which sucks. Well here is my build and everything done to it, this is actually second, the last won blew up.
CAR
250WHP 237 FT LBS OF TORQUE ON 16LBS OF BOOST
LOOKING TO SLEEVE TO PUSH MORE BOOST
1993 CIVIC DX HATCH
SUBARU BLUE W/ BLACK STRIPS (METALLIC FLAKE)
[BLOCK
d16z6 block
.40 over FORGED WEISCO PISTONS (had to go bigger cause of last motor blew up)
Scatt Connecting Rods
HEAD
FEARRA VALVES
CROWER VALVE SPRINGS AND RETAINERS
FULL 3 ANGLE VALVE JOB ON HEAD
INTAKE AND THROTTLE BODY PORTED
TURBO ACCESSORIES
GREDDY 2.5 TURBO PIPE
GREDDY TYPE RS BLOW OFF VALVE
GARRETT T3T4 TURBO 57 TRIM
DRAG MANIFOLD
3 IN DOWNPIPE (CUSTOM MADE)
38MM TIAL WASTGATE
TURBO XS BOOST CONTROLLER
PRECISION INNERCOOLER
550 RC INJECTORS
EXHAUST
3INCH MAGNAFLOW MUFFLER AND EXHAUST SYSTEM
WHEELS
15IN SLIP STREAMS W/ BF GOODRICH DRAG RADIAL (225/15)
INTERIOR
INTEGRA FRONT AND REAR SEATS
SUSPENSION
OMNI FULL RACE SUSPENSION
FULL STRUT BARS
OMNI LOWER CONTROLS
250whp on 16lbs of boost with a t3/t4 57 trim??????
seems a little low to me....but it sounds like a really nice setup......what kind of dyno were you running on?
How come you didnt go beyond 16lbs????? was pump gas limiting you?
YES pump gas was limiting me very much so, i wanted to be safe, this was a very safe tune, with e-85 i should be able to pick up 80 horses by just timing thats it.
what would be a safe amount of boost with good tune on a d series , stock block with an exception with piston and rods, .40 over pistons
You want more power? Forget about sleeving the block for the time being and swap that log manifold out for something tubular. Start there and you'll see the power come a lot sooner.
Get a better manifold!
Get a better tune/engine management!
Get a cam!
There are some suggestions.
stock sleeves have been seen to go +400 whp so i think youll be ok even if you are bored out by that much, definatly look into a better mani.. possibly a topmount or ram just my $.02
PS those numbers on a mustang dyno?? and the setup seems good
it was on a jet dyno
Nice ride.
Do run them DR's daily? Or is this a DD?
What EMS are you running?
Your build has alot more power to be pulled
crome ems, no its not a daily driver, i have a subaru 2004 daily driver. i run drag radial all the time. i think i can get more timing and more boost
Discussion Starter #16
also that was dynod with out VTEC!!!!!!!!!!!!!!!!!!!VTEC KEEPS FREAKIN OUT WHEN enages in third gear pulls, oil pressure drops from 90 to 40psi, i dont know why at this time. thats a big power loss and im goin to go bigger cam...so vtec is turned off at moment but still shits and gets
looks like tha might clear the ac if it was there... lol... I am looking for something like this... actually almost identical to yours.. I just need to make sure it will clear the ac.... hmmmm
1 - 20 of 36 Posts
