Likely, your PGM-FI Main Relay.
1. Remove glovebox, should be to the right, mounted with one 6mm bolt.
2. Google around about "re-flowing" the soldered joints on the board, inside the housing of the relay.
I'd recommend picking up a spare (think junkyard), and practicing on that, even if you can solder well already, it won't hurt.
