1 - 6 of 6 Posts
H
MY ZC IS DRIVING ME INSANE. WHEN YOU FLOOR THE THROTTLE ITS LIKE THE CAR DIES THEN GOES. I WAS GETTING A CODE 7 FOR THE TPS SO I CHANGED IT AND IT STILL DOES THE SAME THING. IF ANYONE MIGHT HAVE SOME IDEA WHATS WRONG PLEASE HELP ME OUT. :mikej: :mikej:
H
no i thought as long as the check engine light went off that it was good
H
Whats This About
I COPIED THIS FROM ENGINE REPLACEMENT.COM "PURGE CUT SOLINOID VALVEWILL NEED TO BE FED INTO THE IDLE UP DIAPHRAMS VACUUM HOSE DUE TO LACK OF VACUUM SOURCE ON THE ZC INTAKE MANIFOLD" WHATS THIS ALL ABOUT :thehump: :thehump:
D
i didnt kno you could set the tps until my mechanic did it right in front of me so definetly get that checked
1 - 6 of 6 Posts
