1 - 11 of 11 Posts
EJ6
I am doing a vitara build on a d16y7... I will be running anywhere between 10-15 psi on a t3 60 trim.
Pistons: 75.5 ycp vitaras
Rods: Eagle H beams
1. What is my ideal piston to wall clearance?
2. What piston to wall clearance is acceptable?
3. Am I able to reliably drive a vitara built motor on my stock computer and injectors to break it in and then boost it when it is broke in? Or is the lowered compression going to throw everything out of whack?
If anyone else had any little questions like this when they were ready to do there build can you please post them and the answer (if you know it) because there is a good chance I may have the same questions
EJ6
will it run correctly though?
I cannot find the thread you speak of on OCO
EJ6
that should be stickied on here
if an OP reads this I recommend a sticky on the above post's link
ptw-0.0035 -0.004
don't boost it on the stock injectors and ecu, if you still have an obd2 computer your going to have issues anyways, unless you kept the y7 intake manifold and IACV.
EJ6
I will not be boosting on the stock computer
Break-in
I plan on breaking the motor in NA on stock computer (P2E OBD2), stock injectors and a skunk2 intake manifold
the main differences between this and my original motor will be
- 75.5 vitara pistons
- eagle rods
- skunk2 intake manifold
then when the motor is broke in
Boosted Set-up
I plan on setting the motor up for boost, installing RC 550's, and using a P06 (OBD1) ecu and getting the motor tuned for boost
should my car run fine on my break-in set-up?
EJ6
someone must know if my car is gonna run???
c'mon!!! :p
EJ6
thanks James... that is good news
Mr. Si... I am plan on having my arrow pointing towards the flywheel
1 - 11 of 11 Posts
