1 - 20 of 50 Posts
July 27th, 2006. We havent set a date yet, But here is my opponets set-up.
Car:
1988 Honda Civic CRX DX
Motor:
JDM D15b Vtec yup Its a Single Slamer
Fuel:
450cc Injectors
Walbro 255L
BLOX Racing FMU
BLOX Racing FRP
AEM high flow Fuel Filter
Head Work:
Port N Polished
5 Angle Valve Job
BLOX Racing Tuner Series Turbo Cam
AEM Tru Time Cam Gear
Blox Racing Titanium Retainer
Blox Racing Valvespring Kit
FERREA Competition Plus Series Valves
Lower End:
ARP Pro Series PERFORMANCE Head Stud Kit
Cometic Turbo & Nitrous application Head Gasket
Blox Racing Block Guard
Bored .040 over
SRP Turbo & Nitrous Pistons
Crower H-BEAM Connecting Rods
Drivetrain:
Spec Stage III 4-Puck race Clutch
OBX-R LSD
Stock Half shafts for now
DC Short Throw shifter
Suspension:
Tokico Struts
Drop Zone Coil Overs
Si Rear Sway Bar
Off Brand Strut Tower Bar
Forced Indution:
OBX Turbo Manifold
Garrett T04E Turbo
Custom Down Pipe
Turbonetics Evolution Wastegate with 6psi spring
Sard R2D2 BOV
GodSpeed Intercooler
Ebay Stainless Steal 2" Hard Piping
Earls High temp Lines
Nitrous Express Intercooler sprayer kit
Electronics:
P72 ECU
obd0 to obd1 Conversion
Greddy E-Manage
Apexi SAFC Neo FYI its Gangster as f**k
AEM Wide Band
Auto Meter 35psi Boost Gauge
Auto Meter Oil Pressure Gauge
Auto Meter EGT Gauge
Blitz electronic Boost Controller
My set up
Car
89 crx si
Motor
Head- JDM B16
Block- USDM B18A1
Fuel
Walbro 225 LPH Fuel Pump
450 DSM Peak and Hold Injectors
Head work
Street Port and Polish
4 angle Intake
3 angle Exhaust
Titanium Valve springs and Retainers (not installed yet)
GSR cams (Replacing with Skunk Pro's stage 3)
Everything replaced with HONDA OEM gaskets
Skunk 2 Adjustable Cam gears
Bottom
JDM B16 P30 Pistons
ARP Rod Bolts
9mm Head studs (forgor what brand)
Stock LS rods (Modified to fit rod bolts and balanced)
Unorthodox Underdrive Pully
B16 Oil Pump (Blueprinted)
Drive Train
Cable JDM B16 Y1
90-93 Integra Drive shafts
act x-act flywheel
xtreeme pressure plate
street disk
Suspension
DC sports Rear lower Tie bar
DNX front coilovers
Stock rear struts (for now)
Electronics:
PW0 JDM Vtec ECU
Socketed and chipped
Crome Pro
Gonna be a good one huh? By the way, Im not done yet :TU: I need come better rods......can you say making power at 9000 RPM's?
Right now 8300 because of stock b16 Valve springs :TD: But I have titanium Valve springs and Retainers :TU: Im going to have Bob send me a chip with a higher launch, and Im thinking a 9000 redline. But I need to get it dyno'd to see where my car stops making power. No need to have a redline much higher than where Im not making power
Ranger - work truck
why are you going to race, last year, shouldnt you have a result of this race already.....?
July 27th, 2006.
hmm, do we all need to time travel to see the race....?
lol git r dun
I think their ls...huh, Ill look into a good set somewhere.
ls bearings are the weakest b16 are ok but gsr bearings are the best..you have to have the tang regrooved to use in a ls block, but gsr bearing will not flake at high rpms.....
yellow bar for me
viper blue 92 eg
the bearings are not all at fault for being weak in the lsvtecs. the ls bottom ends do not come balanced like the gsr and b16. at high rpm you have alot of vibration which causes wear on the bearings. inorder to rev that thing to 9000 safely you are going to have to balance your entire bottom end.
Discussion Starter · #14 ·
The rods are ballanced. I talked to a local engine builder. He said there isnt a problem with Rod bearings. As long as their in the tolarances, and put in right, He said they will be fine. He built motors that revved to 9500 on stock rod bearings.
Lifetime Awesome Member
'89 CRX HF
funny...LS uses the same main bearings as the b16 and gsr do...
Discussion Starter · #19 ·
Im going to be running slicks. I found a guy in NJ, that has a set of Mickey's 24X9X13 on some Lenso's 10 passes:TU: $350 picked up. But Im scared Im going to snap an axel:(
1 - 20 of 50 Posts
