1 - 10 of 10 Posts
My civic
So today I got my hands on 5 quarts of AMSOILS 100% synthetic 5w 30. I mean I was so excited I had the oil already drained before the UPS truck came.
My car has close to 200k miles, so i want to get the most out of it as I can. I took off the POS Fram TG filter and didnt pay attention to that little rubber seal on there. So I put the new K&N filter on (i'll never use another fram after reading reviews) and that seal from the fram stuck on the block and I didnt pay any attention to that. I put the new K&N on and then installed my new magnetic drain plug. I poured precisely 3.5 qts of amsoil into my car, I started it and my low oil light was on. I immediately shut off the car and looked under the car and there laid 2 quarts or more of amsoil on the ground. That expensive and it was just laying on the ground ruined. So I took off the filter to inspect it and I noticed that seal. I took that seal off and reinstalled the K&N and now things are all well. BUT I have a question, I didnt have enough amsoil left to fill it. Well it was inbetween the low and full dots on the dipstick. I used castrol syntec to get it to the top, not even 1/4 of a quart of syntec. Do you guys think it hurt the amsoil mixing that little bit of castrol? I'm ordering another quart for when it uses a little (thats why I got 5 quarts in the first place was because it has a small leak). So do you think it will be okay? I'm going to change it at 7500 miles.
10 second daily driver :)
you would have been fine being 1/4 low no need to add teh castrol, you could have driven like that long enough to get another quart.
My civic
I mean you all may not believe me, but I can honestly feel the difference. It's so much smoother now, even at idol. I mean the syntec was what was in it before so there is no way it could all be out anyway right? So a little extra wouldnt hurt. the next oil change though i'm sure by then the amsoil will have done flushed out all the syntec.
amsoil is one of the best it will feel better, royal purple is the same way.
My civic
Indeed. It feels ALOT better, even idols a little higher. I'll never buy another fram, ever.
dude, ill never use fram because of the seals sticking to the block. its a common problem with them.
lucking i had my eye on my oil pressure gauge and shut my car down within 10 seconds.
never, ever, again.
Let's Go Oakland!
99 EX - 13 EX
How is this a horror story...
A horror story would be working at Goodyear and having all your co-workers call in sick so your stuck at the shop alone on a busy day and you have 4 cars up at one time and you forget to reinstall one little oil drain plug and back the car out the shop with the customer standing there...
seals only stick to the block if you fail to install the filter correctly.
I've NEVER had a seal stick.
But dad did, pumped 5 quarts out of the Buick real quick. I was maybe 6-7 and all I could do was point. Dad wisely shut the motor off to look. That was when I became a gofer :)
"Get me the dish soap and a beer!"
I'm still one to watch over motors when being first started or helping Blundar on the dyno.
PS, 13 years today my father passed away.
1 - 10 of 10 Posts
