1 - 20 of 385 Posts
Lifes short, drive fast!
My EJ1 Vitara Build Thread (updated 9-19-08)
Its 300+whp or bust on this one!
The Victim:
-1994 Civic EX Coupe
-Manual
-210,000 miles
The Motor:
-All D16z6 parts
-Except for the A6 block... (bored .5mm over, notched for rods)
Turbo Setup:
-Bullseye T3/TO4E 50 trim w/ .55 a/r
-GO-AUTOWORKS 3" SS Downpipe
-GO-AUTOWORKS Dumptube
-Ebay Cast Manifold
-Tial 38mm Wastegate, 10psi spring
-Tial 50mm BOV
-GO-AUTOWORKS Tuner Charge Pipe Kit, Bead rolled
-GO-AUTOWORKS 28x12x3 FMIC
-Tuner Toys Stealth Oil Lines
The Parts (will update as more are added):
-YCP Vitara 75.5mm Pistons
-NPR Rings
-Eage H-Beam Rods
-ACL Rod/Main Bearings
-OEM Timing Belt
-OEM Water Pump
-Shimmed/Ported Oil Pump
-.037" head gasket
-Holley Fuel Regulator
-ARP Headstuds
-Gator Axles
-Stage 3 SPEC Clutch (300tq capable)
-Balanced Polished Crank
-Fresh gaskets/seals
-Precision 780cc injectors
-Walbro 255 Fuel Pump
-Tuning sofware: crome
-OEM Tensioner
-GM 3 bar
-AVID Billet Motor Mounts
-Tuner Toys MAP adapter
some parts pics
and the a6 block/z6 head
cleaned up the head/block today, really liken how it came out. degreaser and a toothbrush FTW
question, shud i be able to turn the cam gear by hand?
01 Ford Focus SE
your build will be nice when your done. How much boost do you plan to run?
betwwen 15 and 20psi, as stated, wutever it takes to get to 300whp
Very nice man, I'm jealous... can't wait to see it come together!
I'm subbin' on all the current Z6 builds going on on the "d"!
What head gasket is that?
haha, ya i cant cant wait either :) to bad the gpd damn machinists are 3 weeks out
With the springs still in place, you should not be able to turn the cam by hand. Have fun with your build.
rep :)
question- ive been researchin a lot of the build threads and im questioning my injectors... right now i have 550cc's and im not sure if they are going to cut it, it looks like most are running 750's or 1000's... wut do you guys think?
new balanced/polished z6 crank came today :D ended up payin 75 shipped
not sure wut brand, .037"
Well?
wow good deal for the crank. i think you nned a tripod for the cam man lol.
Well?
not really sure around here never looked into, but getting just a crank that cheap aint bad
1 - 20 of 385 Posts
