1 - 11 of 11 Posts
1989 CRX Si
Hello All,
After being a Mustang owner for many years, I have recently stumbled upon Hondas, and I am now a proud owner of a 1989 Honda CRX Si. I endurance road race the CRX a few times a year. Please find my mod list below:
Engine & Transmission
D16 DOHC ZC - Stock
Cold Air Intake
Griffith Radiator
Light Weight Flywheel & Stage 3 Clutch
Mfactory Gear Set (Retained 4th & 5th Gear)
Carbonized syncro trans
4.25, Quaife
Brakes & Suspension
Stainless Steel Brake Lines
Stock Calipers
ABC Yellow Pads
Coilovers with Koni’s
Adj Ingalls Upper Balljoints
Integra wheels with 195/55/15 Dunlops
Safety
Roll Cage with NASCAR Door Bars
Fire Suppression System
MOMO Race Seat
5 Point Racing Harness
Quick Release Steering Wheel
Body
Lexan Windows
Carbon Fiber Hood
Fiberglass Hatch
I look forward to learning more about the Honda community.
Rob
Tape-R taper/driver
EC3, ED8, ED9, EE5
Looks like a good start.
Mostly Chump racing?
With the 4.25 FD, you might consider either 195/50-15 or 205/50-15.
I'd suggest a 7.5 or 8" wheel and run a 225/45-15
Retired From Hondas
I would agree if speeds and lack of traction was present. But a set of sticky narrow tires and the narrow wheels would cut down the upsprung weight.
But like I said.. track conditions and speed would be a deciding factor to move up to larger heavier wheels.
Love the Civic
mmmm zc crx.....so simple, so good.
EG8
No experience with your setup directly, but integra brakes all around in my B20 pan at maybe 70% threshold braking coming off a decent mid-speed sweeper... That made my oil warning light flash... But I was also running 1/2 full(1/2 on the dip stick, so maybe 3qts?) of oil at the time.
Anyway I'm diggin' this new crop of "noobs"...
Comes to the forum with a racecar racecar. Not questions on how to build a psuedo-wannabe-racecar-daily. :bigok:
Welcome!
Tape-R taper/driver
EC3, ED8, ED9, EE5
Considering they are running a 195/55-15 currently, that is a little over-sized, especially with the lower 4.2 FD.
Dropping down to a 50 series tire will help get some acceleration back.
1 - 11 of 11 Posts
