1 - 9 of 9 Posts
hey guys i have a y8 mill .002 with 2layer HG, aem CAI, Kamakazie 4-1, greedy cat back..timing is at 14*
thing is i always check my mpg to see where i'm at..today i fill up 8.256 gallon and everytime i fill up i reset my trip...i was sitting at 311 with only 8.256 fill up last time i fill up i had 366 and i fill up with 9.115 gallon..
do the 96-98 civic come with a 10gallon tank or 12 gallon tank??
i drive 45ish mile to work 5days a weak, 90ish mile each day..so i always watch my mpg.. anyone else has the same mod what can comment on mpg??
gao
well if you reset your trip last time you filled it up than you used 8.256 (+/-
a little) gal. to drive 311 miles and my calculator says you got 37.669 miles to the gallon. pretty damn good! It does not matter what size tank you have when calculating mpg. :hammer:
That mileage seems right for your setup. AEM cai is da key :)
With the y8, cai, 4-1 header, and custom 2" catback, I usually get 34-36 on my sucky Autovalue oxygen sensor. Still runs a little rich, I go through plugs every 10k miles. Can't wait to see what mileage will be after I finally can afford the $175 OEM sensor.
well my b7 dosnt have any mods other then a CAI...but i can comment on the mpg and tank size...without runnin the shat out of it i get 38-40 mpg highway with a 4 speed...and the manual SAYS its a 9.9 gallon tank, but when i fill up from empty i always see 10 1/2-11 gallons..and its a 91 hatch
J
gao
since you milled the head I assume your running high octane. If that is the case, you could probably advance the spark timing a little bit, and that would increase your power and also help your MPG. Although with the mods you have you are right on avg. as far as mpg.
sweet..thats alot guys..i though i civic was getting like 30/34mpg only stock..but with the mods it seem i gain more mpg..i'm running shittie 91 gas only..my timing is at 12* ATM was going to push it to 14* but didnt want to push it with the mill head..so i left it alone..i'm hoping i can get a free tornado thing and it for a weeks to see what happen to my mpg..LoL..tornado.. i rem some guy wanted to race and all he had was a tornado..i was like WTF
91 LS all stock w/tornado Flashing $500 want to race my 91 Si crx with a JG Street/strip Redline motor...haha that was the fastest $500 i had eva made..
Good MPG!
1 - 9 of 9 Posts
