1 - 4 of 4 Posts
N
I have a d15b1 head i am planing on putting a a6 cam into and turning it to mpfi. I plan to use the y8 intake manifold but havent found any write ups with the y8 im used. I plan to go turbo with this head and the d15z1 vx bottom end. I need to know if i can use the y8 injectors, resistors and etc. or if ill have to use si injectors and such? If anyone could help me out or direct me to a write up id apprecite it.
'91 CRX Si
you can use whatever injectors as long as they are 240cc, does not matter the obd or type (saturated/ peak and hold) as long as you take out the resistor box you are good to use y8 injectors
N
The car was already wired up for mpfi for my b16. would i need to change any wiring?
1 - 4 of 4 Posts
