1 - 4 of 4 Posts
Hey guys i have a newer d15b2 in my car, i was wonderin should i do the mpfi swap or should i just swap in d16a6. and also does a header for a d16a6 fit my engine. thanks
-JJ
Ikillyoutillyoudiefromit
07 Si Sedan
Do you know how to swap an engine? Can you get an A6 for cheap? Then go that route. You will still need to do the MPFI conversion regardless since your car is wired for DPFI. A header for an A6 will work on a B2. Any d-series header will fit, but you may need to do some custom exhaust work.
well i could do the swap. but no i cant find an a6 for too cheap later on down the road i want to do a z6 swap. so i guess i will just do the mpfi swap for now and drive it.
1 - 4 of 4 Posts
