1 - 4 of 4 Posts
A
I have a 90 dpfi hatchback and i got the si engine harness of a mpfi civic in the junkyard and i was wondering if this harness will fit in my car and the mpfi ecu or will i have to still switch 2 wires at the ecu to do the swap?
J
it will work but its more of a hassle, its easier to just cannbilize it for the plugs and such that you need to add on to your dpfi harness. (for instance keeping the resistor box wiring oem, and injectors wiring harness oem ) makes the swap alot easier.
-Juan
A
I gues i could sell it one ebay for 100 and the resistor box for 40 and use the money to get rywire.com to convert my dx dpfi harness to the mpfi z6 one to run my p28 ecu and vtec head.
J
dont expect to get that much for the resistor box (mine from upick was 7)
Your going to have to run your own wires for the vtec solenoid anyways since they are neither on the mpfi or dpfi harness from that year.
Also remeber the resistor box goes with 88-91 injectors they switched style for the z6 head.
-Juan
1 - 4 of 4 Posts
