1 - 6 of 6 Posts
J
Okay I have everything and I started my MPFI swap, but I did forget to grab the d16a6 dizzy connector (the 7 wire i think) that plugs into the dizzy plug. My DPFI plug is square and the A6 is circular. My question is I know i need the engine side of this plug connector (where the dizzy connector mates) but where can i find it beside the local junkyard (which it is always missing) is this a generic plug that I can pickup new somewhere, or does someone happen to have one.
Or is there another way to wire up the Dizzy?
Thanks
-Juan
J
okay so I should solder C1 and C2 directly to the electrical connector plug? (I am not understanding) I thought I needed to find the d16a6 circular plug engine side, to replace the DPFI square style plug, and then do the C1 and C2 connection. Or am I totally off.....
-Juan
J
Thanks for the workaround Dog, I just might have to do it Ghetto fabulous style...... (although I will probably make my own quick disconnects for the 2 wires just so its not a total pain in the a$$ to remove the dizzy)
Thanks again!
-Juan
1 - 6 of 6 Posts
