1 - 2 of 2 Posts
1992 dx hatch d15b7 has a firewall mounted map sensor and im swapping to a d15b vtec(from a 1995 dx hatch) after i get everything ready. After I repin the engine harness side of the 14 pin plug for the vtec wires can i just unpin the map sensor plug wires and pin 5 6 and 7 on the strut tower plug for my d15b vtec intake mounted map sensor? I assume it will work out just fine but then again everything is not always easy.
1 vtec solenoid 2 3
4vtec pressure switch 5 6 7
8 9 10 11
12 13 14
no need to unpin, just unravel the wires from behind the fuel filter, it will then reach the MAP on the TB.
1 - 2 of 2 Posts
