1 - 11 of 11 Posts
block is okay head just got from runing car starts n everything but motor just shakes front and back need help ASAP... thanks
see above
check your motor mounts.
get the motor dampaner thingy
Reactions: Steve-O
Discussion Starter · #5 ·
no its not.. that my motor moves forward n backward plus once i press the gas it makes a weird noise like plup plup plup
civic coupe
are you sure you checked the rear tranny mount? a plup plup plup is better than a knock knock knock
Sounds to me that firing order is off. And possibly a worn mount or two. But check the firing order on the spark plug wires.
Reactions: singlecizam
Discussion Starter · #11 ·
my idles good.. firing order is good bbhut still my motor moves forward n backward same thing plup plup plup when i try to put some gas to it the motor wants to shut off but doesnt 90 civic DX z6 block, head, intake manifold obd1 everything rywire harness
1 - 11 of 11 Posts
