1 - 9 of 9 Posts
I need suspecting I need a transmission mount for my EG.
I can't afford a full motor mount kit right now so I guess inserts is the way to go.
Are they inserts a lot worse then the actual full motor mount kit?
How easy is it to install the inserts vs. full kit?
Any recommendations on Insert kits with ALL motor mount inserts and transmission insert.
Thanks!
I went the cheap route and filled mine with a tube of poly. It worked out ok but there a lil stiffer than i like. If you do this and have any loose panels or any type of rattleing inside the car at idle be prepard it'll get 100x worse with these mounts
eh inserts are just easier.
but if ya want to cheap out. Window Weld, put it in the empty space of the mount
I actually think the insterts are cheaper...depending on how many mounts you fill/how much you put in
1 - 9 of 9 Posts
