1 - 6 of 6 Posts
Can anyone give me some advice on where to get Polly mounts. I've looked on the net and keep find b swap mounts. I have 89 civic si with a d16a6 that I want to build up.
Not so much a direct answer to your question, but, as opposed to using poly mounts/inserts you can instead put sections of fuel hose into the gaps of the motor mounts. It's what I did on my current civic. My last car ('90 crx) I used energy suspension poly inserts - and honestly, I am much happier with the rubber fuel tubing instead. Nice and stiff, and cheap, and removable. :)
I've done window weld in the past. Dries in a day. U do have to remove the mounts to do it but it makes them solid. Only ended up costing about $12.
The hose idea is better since u can take them out but my mounted were torn up so the window weld was a better option for me until I got some nice mounts
1 - 6 of 6 Posts
